T therealdeal Lurker Sep 26, 2010 #1 whats the best crystal talk setting? what setting do you use? normal, clear, crisp or bright?
TelusMilestone Android Enthusiast Sep 26, 2010 #2 therealdeal said: whats the best crystal talk setting? what setting do you use? normal, clear, crisp or bright? Click to expand... I use clear and have never had a problem. I was hoping it would do what it states! lol
Szadzik Extreme Android User Nov 15, 2010 #4 therealdeal said: up!!!!!!!!!! need more info on the settings! Click to expand... Test and choose what you think si best for you as we do not know what you might like or dislike.
fejker Well-Known Member Nov 16, 2010 #5 I removed crystal talk from the sys/app folder using root explorer. Didn't seem to do much for me with any setting - the defaults work for me.
Szadzik Extreme Android User Nov 16, 2010 #6 fejker said: I removed crystal talk from the sys/app folder using root explorer. Didn't seem to do much for me with any setting - the defaults work for me. Click to expand... Did the same the very first moment I flashed the latest ROM and every previous one.
