LeeHarvey42
Does s2e work on ctmod final ver.?
So no way of increasing internal memory ?
After you set it to DATA, did you IMMEDIATELY reboot into recovery ( holding your power button for a second down, then Reboot, then Recovery ) and RE-FORMAT your SD-EXT again ???? ( whenever switching modes from DATA to SSM or visa verse, a immediate re-format of the sd-ext in CWM is required )
