Root CTmod 3.6 with extras
rfrayer
Member
This is not my rom it is CTMod with a few build prop tweaks and a few programs added. Heres the main changed I made
1. Added Star Settings from a comlete different rom (it works and gives native tethering) got it from below
http://androidforums.com/transform-ultra-all-things-root/454412-acs-star-scrom-transform-ultra.html
2. Added Foxfi .
Download from:
Sorry Ive decided to no longer share work with this forum
1. unzip
2. compy to clockworkmod/backup
3. reboot into recovery
4. reset to stock
5. wipe dalvik
6. restore
it isnt a flashable zip unzip it and stick it into the clockworkmod folder where the backups go and use the restore option after wiping and wiping delvik
one quick question if i were to do another rom that u install with zip from the phone not recovery. would i have to do anything extra or the same thing
i beieve you can use sdk to clone your rom into a flashable zip, i just dont see the point of it if you allready have cwm. most peoples roms for prevail are flashable
If this ROM contains the paid Root Explorer from GooglePlay, it is against AF policy to add paid apps to custom ROMs.
Just wanted to give you a heads up if it is that app so you can remove it before the MODs take action against you.
So was paid apps removed? I want to try this out but I will not support roms with paid apps in them.
don't think there was a paid app like i call es file root explorer cause it mounts system but i could be wrong
Like Kris said, I'm not sure it was a paid app. I just wanted to let the author of the thread know that if it was then it needs to be removed. I would say that since the MODs have not said anything that it is OK. :D
Cool, I think I'll go ahead and try it on for size. Let you know how it goes.:)
I lost my phone at work today.:puke:Maybe someone will find it and turn it in.:(
hopefully someone will be a good person at heart and do the right thing. also should have installed an app to find a lost phone or be able to wipe it from another phone. i did after someone else's got stolen and they told us about it.
Yup, Avast does a good job with that......... lots of options available to remotely control your phone in stealth mode ! ;)
Somebody found my phone and turned it in to security. WooHooo!! Thanks guys for the suggestions. The first thing I did was put Lookout on it. If phone is powered off will it boot your phone remotely?
Glad you found your phone. for lookout I don't know most won't reboot your phone they will just find your phone even though it shuts down or it'll turn your phone off lock it or wipe it.
hey... was wondering if foxfi was working for everyone. It force closes when i try to start tethering.
