London and New York are default entries. I wouldn't sweat them.
If you're in Pittsburgh and can't see info about PGH at all, then I suspect something's broken with the feed from AccuWeather. FWIW, I just checked my DINC2 and it's still Detroit-free. So far, so good...
Try this to clear things up:
From the main home page, hit the Menu button, tap Settings, scroll to Location and tap that. E911 should be checked buy shaded or dimmed. Check VZW Location, Standalone GPS, and Google Location Services. (yes, this does pose some risk of data capture about your location, but if you want the local weather, "ya gotta pay to play" - sux but there it is) Go back to the main home page. Do a long touch on the time/weather widget and drag it to Remove, which will show up in the lower right corner of the screen. Do a reset (hold down the power button to get the Power Options menu, tap Reset and tap Reset in the "really reset?" dialog).
When the DINC2 powers back up and gives you the main home screen, tap on Personalize (the paint palette icon in the lower right corner). Tap Widget and scroll down to Clock. Tap that and choose the weather/flip clock. Ignore that it says London on the clock. Tap Select. You'll get "Select a city", which should show a bar marked "Current location". Tap "Current location" and you'll see "Weather options". "Show full screen animation" will be checked. Tap "Done" at the bottom of the screen. You should now come back to the main home screen, with the clock in place, showing your current location's weather and time. Tap on the time, and you should see "World Clock" showing your current location's name and date, and the local time in a box to the right of the name.
Let me know how this all works out.
