Root Custom boot animation not working
toke_
i did everything right and i put the zip under media via usb and when i rebooted my phone it didnt come up. Just the boot animation that comes with ICS gingersteem rom. does this not work with custom roms? or how do i find where the ICS theme puts its boot animation and ill replace it?
get ur custom bootanimation and place it in ur system/ media and rename it bootanimation.zip the one u have in there just move it to ur sd for bck up,after just reboot c if it works do all that with root explore u should b good
i found an actual boot animation folder but it says all the files are real only or somthing like that and i cant move them or delete them.
no not that folder go to system / media u should c the bootanimation.zip along with audio paste ur bootanimation in that folder and just rename it bootanimation.zip the other one have in there delete it or move it to sd card if dont move or delete it will not work
ps before u could rename it u should see on ur right hand corner ( r/ w ) click on it u should c it change to ( r/o )
when i try to move the old bootanimation.zip or paste the new one it says " bootanimation.zip cannot be moved because the file system is read-only."
but i did find the right folder :P
nvm i found the r/o up top and i got it to work. im about to see if it worked
edit: it worked! but the pictures went by so fast.. i changed the FPS to 1. testing now
glad to hear u got it working,u also could changed ur sound when it boots up,just download any song or beat that u want just make sure its mp3,once u download it look for it from ur sd card using root explore once u find it copy it and go bck to system/ sounds/ power ur gonna c one in that folder already move it or del it then paste it after that just rename.it just like this MetroPCS_ PowerOn.mp3 and it would work
