And where is Talula?
If you mean location? I'm in a small town that's famous for its water!
25-30MB cache. Check current sizes with quick system info for system. Then leave about 5MB extra to play with
I'm running GV v2.1, and it is using (nothing modified from the original ROM) 142MB space.Just wondering if someone can tell me the optimal sizes for a custom MTD running GV 2.1 and also the easiest/best way to do it. Cheers. Lots of love from Talula!
How easy is it to return it back to stock if I ever needed to?
does the phone still run as fast with the custom MTD?
Also, so I would have to create the txt file using notepad? Flash the zip's and that's it, but would need to flash the boot zip on every install?
