I've been using SUroots dGB ROM for a while now and love all the space. What I want to know is would it be possible to do the same thing with ICS? What I hope to do (in the future) is reduce the size of the ICS.zip for the desire (I know its still in a beta stage but this is for future reference) and then set the MTD partitions to the size of the ICS.zip file.
What I'm hoping is that I can use ICS on my desire but still have a reasonably amount of space. What I would like to know is what apps i could remove from ICS that aren't vital for the system and would this process be as simple as following MTD guide and set the system size to whatever the ICS.zip was?
Thanks for any advice.
probably do this in the new year. Thanks very much to both of you.
