Custom Notification Alert
Raytors13
Hello,
Smartphone noob here. I just upgraded to a D3 from a BB Curve 8330 just 3 days ago. I can't seem to find how to set a custom tone for incoming text messages. Can anyone help?
Thanks in advance.
search ringtone maker off of the market, that works. also the app ''zedge" has almsot everything you could think of for notifications and ringtones.
to do it manually you have to create a ringtones folder and a notifications folder under media in your sd card.
Yes, I went there, but that only has a certain list of tones that you can choose. I was wondering if there was a way to set a tone that I have on my SD card as a notification alert.
You can move the sound you want into a folder (make one) for notifications on your SD card.
Media/audio/notifications (new folder).
Same for ringtones, just name it ringtone ;)
You can also open up the stock music player. Pick a song. Long press on the song and it will give you the option to make the song you have saved to your sd card a notification/ringtone sound.
Hello,
Thanks in advance.
Go to the music stock player. Pick a song. Long press on it. It will give you the option to make it a ringtone/notification sound.
Edit. Sorry gor the double post. For some reason i was having a hard time tho. Anyway hope we helped.
I want to THANK ALL OF YOU for your help. With all of your tips I found my tone on my SD card and saw that it was just a simple "Set as notification" button. I was trying to do it from the settings in the droid. I'm so used to the BB Curve, I just have to get used to this phone. Thanks again. Happy to have found this community of Droid 3 users. I'm sure I'll be back again with more questions. :D
