abescalamis
I'M NOT RESPONSIBLE FOR ANY DAMAGE TO YOUR PHONE!!!!! DO IT AT YOUR OWN RISK!!! (Bakup the PowerOff.apk )
Very Important Note "(DO NOT TOUCH THE PowerOff.odex in /system/app/)" in step 7 the battery needs to be removed to complete the process if you don't remove it it will restart from the bootanimation and will not change the power off logo.
You will need winzip and winrar unzip the file!!
Winzip:
http://www.winzip.com/downauto.cgi?....winzip.com/winzip16-32.exe&email=&er=&os=win
Winrar
http://www.rarlab.com/rar/wrar411a.exe
Instructions:
1) Your phone needs to be rooted.
2) Download winzip and winrar from the link above, you will need them to decompress the Poweroff.apk
3) Download the Zip file in this post and unzip the poweroff.rar in your computer then using winrar decompress the PowerOff.apk.
4) Transfer the PowerOff.apk to your phone internal storage or SD card.
5) Using Root Explorer copy the PowerOff.apk you saved in your internal storage or SD card in step 3.
6) Using Root Explorer navigate to /system/app/ and paste the PowerOff.apk it is going to ask you if you want to overwrite the one that already exists, your are going to select YES!!!
7) Now for the changes to take effect you need push and hold the power off button of the phone and select the power off option, and immediately remove the battery.
Winzip:
Winrar
Instructions:
