Root CUSTOM Rabid ROM ZT282 7" C71 E8_N1 De-odexed
Rabid1
This is a ICS ROM with some build.prop and WiFi tweaks based off the stock 0709 release.
The ROM has been de-odexed. I did not delete any bloat or add any apps. I wanted a full working ROM for everyone to play with as they want it. I will release a small patch with some more visuals and disable some of the telephony stuff. I figured for now a little at a time as the ZT282 C71 can be picky.
There are two files the ZT-UPDATE already configured for the E8-1N using Omarahum's 0709 1GHZ and 2GB Data MOD, with the 1M and 1N files and a backup of the stock build.prop and wpa_supplicant.conf. The second file it the de-odexed jar and apk files both standard and optimized.
Changelog:
Added build tweaks for better WiFi, Streaming, Smoother scrolling and transitions, it should see slightly better battery.
Used optimized de-odexed system files.
Changed default background and added bootanimation -changed battery icons, but they didn't hold - hmmmm.
Replaced stock recovery and kernel with Omarahum's 0709 E8-1N OC'd 1GHZ kernel and 2GB data partition recovery.
Thanks to Omarahum, Torenton, and all the ZT282 users for all the posts that helped get this going.
Upload Links -
ZT-UPDATE
DE-ODEXED FILES
