If you are using custom ringtones from your SD card and then remove the card for whatever reason, the ringtones will default back to the original ringtone.
If this is the case, try making a folder called Ringtones on your internal memory and copy them to that folder. It worked for me and I haven't had the issue since.
PS: The above works the same for Notifications as well.
