Hey all. Fairly new to Android, using a Mac for syncing files. After a lot of searching for a simple way to sync over ringtones, and finding a lot of things that didn't work, I decided to take matters into my own hands, and I copied several custom ringtones that I made a while back over to my phone's default location for these, /system/media/audio/ringtones. I used a utility to mount the filesystem as rw, copied the files from my SDCard, rebooted the phone.
The files correctly showed up in the file listing, but would not play. Existing ringtones worked as usual.
I had saved these as OGG format, so I decided to convert them to MP3, copied them back over, rebooted, same issue, not playing. I fired up the Music player, found my new ringtones listed there (possibly they were scanned off the SDCard, since the files were still there?) and they play just fine.
I'm a little bit stumped on exactly what it takes to make an official ringtone on android.
For what it's worth, I'm using a ZTE Avail 2, using the Azazel ROM posted in the Prelude forum (same phone, different carrier), forum thread here: http://androidforums.com/prelude-all-things-root/795640-azazel-rom-z993-aio.html
I checked the ringtones included on that ROM, and from what I can tell there are no obvious differences in the files. The ones on that ROM had ID Tags showing author and other information, one thread I found indicated that ringtones shouldn't have tags, but obviously they can. Some of the ROM files were stereo, so that's allowed. Encoding matches as best I can tell, tried using a different audio converter app, no change.
There has to be some magic here that I'm missing...
