Root Custom Rom- Applications Force Close
legend76
Hi there
This rooting malarkey is on the higher end of my technical ability so its a miracle I have got to where I am
Phone has been rooted
Runnymede Custom Rom has been installed.
However, when trying to open some applications (Facebook, Internet etc) I get a 'application has stopped unexpectedly message' which asks me to force close.
I have had a look everywhere and just can seem to find a definitive or dummies guide to resolve this issue.
Any help would be appreciated
There are no dummies guides to resolution of technical issue as it requires logical and lateral thinking.
First things, did you meet all the requirements in the thread?
Im asking if you used titanium backup or any other backup application to restore things you had on previous roms? Have you tried a factory reset since the issue surfaced?
no you cant restore application data with CWM. if factory reset still gave the issue, its definitely a rom / your device setup issue. If your partition is big enough on sd ext and you flashed the correct rom for your hboot, recommend trying a different rom
