Help Custom ROM for Ainol Novo7 Tornados???
UrbanRich
Hi to all!
Firstly, let me apologise in advance for anything I may say here that sounds incorrect or stupid. I am basically new to the Android scene, and have had to try and learn as much as I can in the last couple of days.
With that said, here's my problem/situation - I've bought my 4 year old son his first tablet which is an Ainol Novo7 Tornados.
From what I've read I believe it came already rooted (I just had to install Superuser, which I did). I've read about custom ROM's and that they are usually
better than the OS that it comes pre-installed with. I've also read that custom ROM's allow you to install to SD card.
What I'm not sure of is whether which ROM you use is determined by what device you have, which version of Android you're running, or both?
So, could anybody please tell me if what I'm correct in what I'm saying, and whereabouts I can get a ROM for this device?
Thanks in advance, any help would be greatly appreciated!
