Root Custom ROM found
I have tested and the custom ROM is stable so far. WiFi is working 100%! But the downturn is the version which is DXKJ3 that result in "unexpected SD removal" bug. Formatting it into FAT32 does not help at all. :(
I using that rom for 3 days now. It is a very stable rom. its lighter and faster than stock 2.3.6 gingerbread. bloatwares are removed and added important full version apps like titanium back up pro, super user etc. your phone is also rooted automatically when you flash this rom. Wifi is 100% working. You must try this rom its worth it :)
I'm having problems to root my Galaxy Y...
It says that my phone don't have "package.zip" and the Superuser is not working...
If i install this ROM, it will solve my problems?
nice one but not that modified but worth flashing it it's definitely faster den gingerbread 2.3.6 and best part is it is equipped wid full version of titanium which is gr8
Hello,
I'm a french user of that Galaxy Y.
Is that ROM compatible with french users or all the menus are in english only ?
