Root Custom ROM question
Spartanzz
I just got a nexus 7 2013 and would like to use CM7 on. My question is I saw that it shows a Cm7 for the LTE version. Mine is the WiFi version will it still work? Because I can't seem to find a WiFi specific version.
No! Make sure you use the correct version. If you've updated your nexus 7 2013 to kitkat you want cm10.2 or cm11. Cm7 is waaaaaaay outdated. And make sure its for the WiFi version.
Here http://download.cyanogenmod.org/?device=flo&type=
And make sure you use the correct gapps.
Nexus 7 2013 nickname is flo.
Here is some more stuff http://forum.xda-developers.com/showthread.php?p=43983057
