Root [CUSTOM ROM] YDroid v2 ICS Jelly Sensation
oppheng
Ydroid v2 ics jelly sensasions
Features -support swap -support amarulls -more smooth -more saving battery -undervolt script -deodexed -new boot image -kernel with hell fusion#80 -cwm permanent Bug I have not found bug yet. If you found some bug report to fb @firman yoshioka
Instalations 1. Go to cwm 2. Wipe data 3. Wipe cache 4. Mount & storage -change Mount SYSTEM become UNMOUNT SYSTEM -change Mount DATA become UNMOUNT DATA 5. INSTAL zip >>> choose ydroid v2.zip 6.Reboot system
Download link Dropbox : SORRY ! IM CANNOT PUT THE LINK URL, IF YOU WANT TO TRY IT, I HOPE YOU SEARCH ON GOOGLE WITH KEYWORD LIKE THE TITTLE.
attention if you install the update. Disadvantages: if you install this update, the button can only turn off the power to the shutdown button only. if you want to reboot into cwm using the buttons in the statusbar only. advantages: the system becomes more stable and transparent.
if less willing to put on the original course
Theme theme update yd v2.zip" - SORRY I CANNOT PUT THE LINK URL, CUZ IM NEWBIE HERE, IF YOU WANT TO TRY THIS CUSTOM ROM, PLEASE SEARCH IN GOOGLE WITH KEYWORD LIKE TITTLE. THANKS
Instalations update 1. go to cwm 2. instal zip 3. reboot
Thanks and credit Allah Herry cools (created Rom) Hell lock (kernel's) Galaxy Y Gt-S5360 Community@fb Yoshioka ( testing & theming) Oppheng (blogger)
