Root Custom rom.
sookieball
Ok so someone over modmymobile.com has released a semi-stock semi-deblurred rom for the cliq2 ...
I got an MD5 error. But maybe you'll have better luck.
Don't forget to thank the devs behind the rom and as always, spread the word.
It was me. I re-released the rom based off the 1.0.23 firmware. So that means if you have the SOAK update (2.2.2 froyo) you need to flash down using the sbf. Also, did you happen to change the name of the file? If you did, that will give you mismatch error.
