sniper8752
so this has probably been discussed before, but i haven't seen too many custom roms for the aria. are there any good ones out there?
i saw the first link, it requires 2.2? i only have 2.1. the latest aria update does not have froyo, right? what is the cm-6? s orry, new to all of this.
and i just found out my model number is the htc liberty... this is the same thing as the aria?!
What is the difference between update from zip vs install from sdcard
installation aborts when I try to install the rom
I am sure that a new flash would be much easier to do than moving all that stuff with adb.
I have never used reflash 3 before so can not comment on that.
I always used unrevoked3 and then used adb or some other method to get the new rom zip file to the sdcard. Then boot into recovery holding the Volume minus button while you turn on the power. Then select update from zip file and select the file you put on your sdcard. This has worked for me without problems on all tries.
just to clarify this is the unroot recovery tool I am referring too.
Absolute BEST root method for Aria: Unrevoked team's Root/Recovery reflash tool - xda-developers
Is it necessary to partition the SD card prior to installing a ROM?
Update.... I downloaded Rom Manager on the open market and installed Liberated _Aria and it worked!!!! Looks like it's the same as stock minus the bloatware. Maybe I'll try that Cyanogen Mod 6 rom next. Can I delete the zip file now to save space on the SD Card?
