custom round battery icon
kinfolk248
heres a custom round battery icon i made this morning. i didnt really like any of the ones already on here so i made this. Its green 100-60, yellow at 40, orange at 20 and last but not least red at 10. should install via MM. Hope u like...
seems you gave to much to green
10 - red
20 - orange
30 - 40 - yellow
60-100 - green
not sure 60 - 100 range deserves green? maybe 80-100 does
or is this common points?
I just opened up the ZIP. Are the 90, 70, 50, 30 numbers generated automatically? I couldn't find a picture for them.
100-60 got green because normally you should be good to go with that much battery power; it only will show 20% increments as with stock image
