Is there an app to customise the lock screen properly,I am using backgrounds but it does not let me resize a picture properly as i want it on the lock screen.
Is "backgorunds" an app or are you just trying to set the background on the default lock screen? If it is the latter then mine works no problems, just upload 320x480 images to your SD card and make sure the bounding box covers the whole image whn you set it
There are loads on flickr, and deviantart is good for wallpapers in general. The best thing is that they dont have to be the right size - the phone will clip and resize them for you.
