Which version of cwm are you using? The one posted on these forums is the only cwm that supports the transform.
You're trying to transfer a rom from your computer to your sd card while in cwm? It would be easier to do this with the phone booted up and used as a mass storage device.
Cwm built for this phone (the one found on these forums) reboots after 2 mins unless you have flashed a rom during that session. Boost claims that this is a safety precaution to keep people from screwing with their phones. If you flash a rom your cwm will stay on but beware your battery will get HOT.
Hopefully I answered your question.. there are so many different variables with this phone that you have to be very specific lol. Describing the crash where you got cwm from etc... overload us with info please... we can always ignore the irrelevant stuff.
I have been using the cwm interdpth made and never flashed a rom. Never had a reboot problem. My Sprint TU is rooted and has CWM but everything else is pretty much stock.
I think Boost lies. Last post in this thread seems to be the fix for the reboot problem. http://androidforums.com/transform-...7-samsung-ultra-baseband-ciq.html#post4083463
