LDrifta
No Stranger 2 Danger
M931_Stock_Backup_B131
~This is a stock backup with NO trace of ROOT in the SYSTEM!!!
(Does NOT install stock recovery)
Rom Base:
System: B131 (4.0.4)
Kernel: Stock
Download Links:
CWM_Stock_Backup_b131 - Stock Rom Backup meant to be extracted and used in restore menu
Stock_Cust_Flasher - installs all metro apps and carrier files (NEEDED) flash as a rom.zip
Installation Proccess: VERY IMPORTANT
-Download the 2 files
-EXTRACT THE ROM ZIP ONLY
(so now you should have a folder named "clockworkmod" NOT A ZIP
-Now copy the "clockworkmod" folder and "Stock_Cust_Flasher.zip" to EXTERNAL SD card
-Boot to recovery mode
-WIPE DATA!!!
-Select retore/backup menu, then select "Restore from external SD"
-Now selct the backup file and begin restoring,
-Once finished restoring go back to main menu of recovery
-Now your going to FLASH the "Stock_Cust_Flasher.zip" as you would any normal rom
-Once finished reboot the device 7 times!!!
(haha just kidding, want to make sure your paying attention though!!!)
-Now enjoy your new/old/stock/bloated rom
Rom Base:
Kernel: Stock
Download Links:
-WIPE DATA!!!
