RedBunnyJAV
I used Rom Manager,...
Then under the recoveries section I used the LG - Lucid. I know this is a Viper but the model numbers were close 840,...
Then I just pressed reboot into recovery,...
-edit-
Now I seee why not to use Rom Manager. It didnt do the backup properly. It wouldnt save the /system folder ,.... couldnt mount it.
Check this out though:
CWM Recovery Builder
It says it just needs the stockrecovery.img
-edit-
