I think it's pretty much 50/50.
I did hear/read something not long ago that 4EXT was supposed to be truly open source (not 100% sure where I read that though)
I'm hoping to flash Jelly Bean onto my UK Sensation but the post on here says use CWM. My phone has 4EXT as recovery. Please can somebody tell me how I replace 4EXT with CWM? Do I delete 4EXT from my SD card, download CWM and then .... well ... that's where I don't know what to do next. (The phone is properly rooted and currently running ARHD).
Tks in advance.
Phil
yes it's worth getting 4Ext instead of CWM. if you want to install ARHD on your sensation, you need s-off (of you aren't)..but with 4Ext, you can bypass securities of being s-on by enabling 4Ext SmartFlash, which allows the phone to write on the boot partition of the phone like you were actually s-off, which is normally not the case for us s-on users. so with smartglassh enabled, you can flash any rom like you were actually s-off. butbefore enjoying 4Ext, make sure you have installed 4Ext recovery updater apk.and it's true that most of todday's roms for sensation only require 4Ext recovery for the features that support most roms like OTA update flashing, which CWM cannot do.Looking through the ARHD thread in XDA, says you need 4EXT Touch to get it. Is it worth me getting this 4ext, or is CWM better?
