PlayfulGod
Extreme Android User
Ok this is a tester only as I still need a few things to verify a few things.
I need a dump of the stock recovery, will need root, LG USB drivers installed, and know how to use adb.
in adb shell or term on the phone:
from from pc/cmd:
or from term on phone:
I also need hexdump for misc:
And a copy of the vold.fstab located in system/etc
You can either zip all of this together n upload n link me, or uplaod the recovery.img n pastbin the others.
And now for the test cwm;
cwmrecovery.img
Last report I got back, it all works great but booting to recovery with the button combo it wont reboot to system. A battery pull is required to boot normally.
wikidd's fake flash maybe a safer method for the non-savvy.
from from pc/cmd:
Code:
adb shell
Code:
su
Code:
busybox dd if=/dev/block/mmcblk0p13 of=/sdcard/stockrecovery.img
Code:
su
Code:
hexdump -C /dev/block/mmcblk0p25 > /sdcard/hex-misc.txt
cwmrecovery.img
- Download
- unzip
- Have LG USB driver installed
- connect phone up via USB
- have debugging enable
- have in internet connect mode (charge mode if internet mode isnt an option)
- Run the follow from adb shell:
Code:
adb push cwmrecovery.img /data/local/tmp/cwmrecovery.img
Code:
mount -o remount,rw -t ext4 /dev/block/mmcblk0p27 /system
Code:
rm /system/etc/install-recovery.sh
Code:
rm /system/recovery-from-boot.p
Code:
busybox dd if=/data/local/tmp/cwmrecovery.img of=/dev/block/mmcblk0p13
Code:
rm /data/local/tmp/cwmrecovery.img
Code:
reboot recovery
FIX MY PHONE I CAN'T GET ANY RECOVERY AND IT WONT BOOT!
