Root CWMR (Clockworkmod Recovery) For Micromax A25 by VAIBHAV
created a scatter file like this
RECOVERY 0xFC0000
then disabled da download and pressed downlod button it worked and shows a green circle
my device is working now also sucessfuly installed cmw
Well congratulations....use my update.zip to root ur phone...remember toogle signature verification in cwm and turn it off....
If u like it u can donate me for further development....to donate pm me....
Bruno mart is the name of my compiler by which I compiled my cwm...flash boot.img using the same scatter file but instead of recovery erase everything except boot....and then flash it...then root it via unlockroot...
hi dude, while flashing recovery.img to install cwm am getting the error it shows me SP Flash Tool Error(8100) Cannot find USB port ..and another thing i had already installed the drivers for A25 ..
Help me pal,am new to this
VAibhav help me to get rid of the error which occurs while am flashing the recovery.img to install cwm..help me dude
is adb is detecting your device....
when i installed the phone in debug mode in the device manager it shows the android composite ADB interface ,do u mentioning that buddy
Vaibhav tell me the exact procedure to install the driver because its showing the error of cannot find USb port
@Kp27 dude turn off ur a25 and remove battery then go to device manager of ur pc insert usb cable of ur a25 in switched off state in device manager it will show mtk preloder click on that and install driver manually (install usb vcom driver mastermind provided) now try to flash it will not show error
