joe_blow
Member
This is a re-post / cross post of CyanogenMod 10.1 [ROM] WILD FOR THE NIGHT - Sprint/Virgin Mobile
Please refer to that thread for all information and post issues there not here as I NOT associated with this ROMs development.
All my testing is using this ROM on a Virgin Mobile HTC EVO 3D (re-branded to HTC EVO V 4G ). Also if you want the latest and greatest "HTC EVO V 4G Firmware" for this phone please see my other post.
Just a heads up as this ROM now seems to be stable.
Yes it's the current "Holy Grail" of ROM heads like us a CM10.1 ROM
Please note: it's built from Google sources AOSP not from AOKP
Android 4.2.1
CyanogenMod 10.1-20120131-UNOFFICAL-shootervm
This means that other then the Nexus 4, you will have the JB 4.2 Swager!
( Well no swager toggle setting to get that HDF "Hipster Distortion Field" turned on
Features:
Issues:
Prerequisites
Install
Feb. 8, 2013 is the latest update and contains the following updates:
THANK dastin1015 and his contributors! I am just cross posting this information, they deserve your gratitude!
Work-A-Rounds
Kernel
So far this ROM is rock solid no system errors, application crashes or reboots.
But the downside is no kernel features, comes with the stock CM10.1 3.0.61 build.
You can flash the Team Dirt 3.5 AOSP kernel:
DIRT 3.5 now matches the CM10.1 kernel level of 3.0.62! Testing has begun!
WARNING: using other kernels can and has lead to unpredictable phone glitches
Passes all normal stability tests, get's you all the knobs and switches.
I recommend
1242mhz yields 6483 in AnTuTu, that is under-clocked !!!!!
:smokingsomb: 1512Mhz yields 7591 in AnTuTu so I would rather have the battery life
But alas after using for a few days my phone hung on a reboot. Also playing MP3's there are issues with random pauses and pops. So if your into using you phone as a media player don't mess with kernels until there built for the CM10.1 ROM.
Android 4.2.1
) Features:
- Built from CM source
- Service
- Text
- Data
- Calls
- Audio
- WiFi
- UMS
- Google Now
- Bluetooth
- MMS
- Qualcomm JB libs & firmware
- Video playback
- Audio playback
- 4G
- Camera
- Camcorder
- GPS
Issues:
- 3D
- First video recording of FFC and rear camera is messed up. Afterwards fine except some graphical tears.
- Stock kernel 3.0.61 Cyanogenmod+Dastin Thus no ablity to tweak and get better battery or speed.
Prerequisites
- Do not use superwipes
- HBOOT 1.57 DOES NOT WORK!!!!!!!!!!!!!!!!!!! Recommend HBOOT 1.04 or 1.50
- S-OFF
- 4ext recovery or TWRP 2.4.x
Install
- Wipe data, cache, and system (wipe all partitions except sdcard if on 4ext recovery) if coming from any ROM except CM10
- Wipe cache and dalvik-cache if flashing new version from previous installation of CM10
- Flash ROM
- Flash GAPPS
- Reboot
- THANK dastin1015 and his contributors! This is REQUIRED! DO NOT SKIP THIS STEP or your phone will burst in to flames in your hands
- Profit
- JOP40G
- Audio update
- Support for Virgin Mobile MMS (Separate from MMS fix)
- Half press camera button to focus
- Move dalvik cache to data
- Bionic optimizations
- Scorpion optimizations
- Kernel: Linux 3.0.62, Linux 3.0.63, allow only unicast packets when screen is off
- CM upstream
Work-A-Rounds
Kernel
I recommend
- intelidemand CPU Governor, with Linked Cores
- Max 1242Mhz Min 384Mhz ( to save battery normal is 1512Mhz )
- 3D max Freq 320Mhz
- 2D man Freq 266Mhz
- noop: IO Scheduler
1242mhz yields 6483 in AnTuTu, that is under-clocked !!!!!:smokingsomb: 1512Mhz yields 7591 in AnTuTu so I would rather have the battery life
