Root Cyanogenmod 10.1 [Unofficial]
I was looking at this earlier, after ral mentioned that they are looking at releasing a stable version shortly :)
yep, and now is here...just downloaded but my battery is on 16% and i'm going to better world (zzZz) and tomorrow will flashed..
I think they also put OTA..
I was about to download it, than I saw the post about a new version so I devices to wait.
Would be a great choice to run the new Nova 2 launcher on.
On CM 10.1.
Comments so far. Setup took a long time to initialize. Touch screen is unresponsive at this time, so just be patient.
Google voice search Force Closes. Others at XDA have reported the same issue.
Edit: My bad. Update Google Search on Google Play and FC Fixed!
Battery history does not seem to report awake and screen on time accurately.
That is all for now.
On CM 10.1.
and i cant manual select network...every time hits error...i'm on tele2 and signal is very wick, so i use t mobile signal and for that i need to select network..but it's not working..
now back to cfx..
and no OTA
Installed this now and just setting up. Couldn't work out how to turn USB Debugging on... quick search gave me the answer and thought I'd share (for anyone else interested).
"Menu=>Settings=>About phone" and tap "Build number" repeatedly, until you are given developer status... that then opens up the option (a couple up from "About phone") :D
I've come to CM10.1 from CM10 and have noticed a few tweaks... it's really nice in comparison. Gonna have to give it a couple of days to really tell what it's like. I have also enabled Google Now, which I hadn't before, so we'll see what that brings to the table! :)
ive used google now a lil bit... its neat,im sure i am not taking advantage of even a small part of what it has to offer :eek:
may have to give this a go meself :D
It's worth a punt mate... not had it long enough to give any real view on it, other than I LOVE the CM teams work, so am sure it'll be good!! :)
Have just checked the link out, which answered my question! :)
Was going to ask if you had a zip to flash to return to stock, but have noticed that over there too!! :)
The Chrome browser still does not work well on this ROM. But the only DHD ROM where I find that the Chrome Browser works up to Galaxy Nexus standards is aospX.
But weighing between the Chrome browser and all of the JB improvements..., well this will replace aospX in my two ROM rotation. Blackout ICS for when I miss Sense. JB-JOP40D when I get bored of Sense.
Well, its a CM ROM... so anybody can port it with permission.
Almost forgot, obligatory screen shot (I need ideas).
Has anyone else been having an issue with the proximity sensor? It just doesn't seem to work.
I think I had the same issue when running the last build of CM10. I have seen that there is a re-calibration app on XDA and am thinking that I'm gonna give it a go. Just thought I'd share for anyone else that may be having the same issues :)
