OK first off, I did not build this from source
I took the CM10 ROM made by 985hPaKicK and elamarkant
cm-10-20120901-JellyEidtion-HARD.zip and I made some changes to it
It uses 2nd init
A lot of things do not work like RIL, WiFi, Bluetoothe, etc. etc
So this is for devs who want to try to get it working
I am a pretty busy person, so I can not commit my self to getting you guys/gals a fully working CM10, I will help where I can, as time allows.
I think in the long run we will want to build from source and we should be able to use 985hPaKicK source code to accomplish this.
https://github.com/985hPaKicK
I want to thank 985hPaKicK, elamarkant, koush, the Cyanogenmod dev team, and all the devs, testers, and contributers
If you have not already did so, please post a thank you post for 985hPaKicK in this thread.
http://androidforums.com/motion-4g-all-things-root/666214-thank-you-thread-985hpakick.html
Some notes
Install with 985hPaKicK 2nd init recovery
DO A BACKUP BEFORE INSTALLING OR FACTORY RESETING
Do a Factory Reset before installing
After you install this ROM, the proper way to get into recovery is to press (hold) the Power Button, choose reboot, choose recovery, click OK
https://www.dropbox.com/s/786zq85nxf7jmtn/LGM_CM10_PRE-ALPHA.zip
mirror
http://www.filedropper.com/lgmcm10pre-alpha
If you would like to buy me a beer or coffee, you can click on the Donate button
It uses 2nd init
Some notes
mirror
