NetoSenpai
Had a lot of problems using Banks gapps, tried open gapps nano as suggested with no issues.
Spirit FM works
ro. product.name=dracoinsHey hroark13
What's the device model for this I want to and it with build prop editor cause a app don't recognize the phone it say unknown.By the way good work on the ROM run's good.![]()
It's the one that's says unknown I check the other one it got cm dracoinsro. product.name=dracoins
It's not there you'll have to add it manual.It's the one that's says unknown I check the other one it got cm dracoins![]()
I'm just saying before you start saying stuff isn't working. Check the permissions in your app settings. This is going to be the number one reason why apps FC.Beta 2 works like a charm! Fast, stable and gorgeous. Thank you.
Only trouble I'm having is when an incoming call with Hangouts Dialer causes the phone to reboot.
Is there an explanation anywhere as to the newer perms setups with apps and how/what makes them F/C?I'm just saying before you start saying stuff isn't working. Check the permissions in your app settings. This is going to be the number one reason why apps FC.
If an app has a permission and it's not granted it's going to close the app. Android M started letting you pick a d choose what app permission you want to useIs there an explanation anywhere as to the newer perms setups with apps and how/what makes them F/C?
It now does this.I tried your switcher from yesterday on cm and it worked fine as long as you changed permission in app settings.
