I'll leave that to Manup. He updates the CM version.
Well, I re-booted and my root is broken. Time to re-flash. =/
Yeah, I really hope I can get into recovery, because I can't flash from ROM Manager without root...
I got into recovery, but I don't have anything to flash. I can't find where ROM Manager saved it. Does anyone have a link? Or can pull the .zip off their phone and upload it? Otherwise I'm gonna have to flash back to BB before my girlfriend gets mad at me for not texting her back. .___.
Still have root but can't get into recovery. Going to try the SPR->CW trick.
Yes, I've looked all through there. Nothing that resembles the right one. Closest is "Launcher2-CM6-v1.zip" but that one flashed so fast I don't think it's the right one...Go to install from sdcard, and there should be a Clockwork folder that has all your update.zips.
its under cyanogens downloads in rom manager.
Why doesn't my contact photo show up in text messages?
Do you have an entry in your contacts called 'Me' with your photo?
BTW, I'm gonna need some xTheme testers for CM6 soon. Please PM me if you're interested![]()
No I don't..
You're trying to have a picture for 'Me', when you have an MMS thread, right?
If that's the case, you need to have an entry called 'Me' with a photo, or else how else will it know what to show?
If your contacts aren't showing up, then idk what's wrong, since mine do.
I'm running fine on P3's.So are there any other custom kernels that are confirmed working besides jdlfg's?
No direct download link yet?
