Root Cyanogenmod 7 Acceleromter Issues
Yathushan
Hey all,
I have recently discovered an issue with Cyanogenmod 7.0.2.1.
Where Google applications and some 3rd Party applications have not been rotating when I tilt the phone in one direction or another. This is especially bothersome in Gallery as all photos are viewed in portrait.
If anyone else has had similar issues can you click the link below and star issue. Thereby, ensuring that the issue is more likely to be solved.
Issue 3613 - cyanogenmod - Accelerometer Doesn't Function Properly in Google Applications and Some 3rd Party Apps - CyanogenMod Android ROM - Google Project Hosting
Thanks!
CM7 is stable, niggly issues like this can arise when a flash upgrade is done without a wipe. I would suggest a reflash whether you wiped or not, just to see what gives.
Yeah I got a post on the issue about enabling an option which I did not realize existed and now it works fine.
