Root Cyanogenmod 7? optimus m?
hi i am going to buy the optimus M in the next week but i want to know about cyanogenmod 7 for it i really like that rom and yeah is there any links telling me how to flash it and the metroOFF mms fix for it too? thanks so much for your help
oh and also will the recovery thing in your sig worck for cyanogenmod if so how do i install it im having trouble figuring out what they are talking about in the post on your sig
Yes, as long as you are running Android v2.2.1 and are rooted.
Install Custom Recovery
Go to Android SDK | Android Developers and download the file that ends with .zip. Extract it to your C:\ drive. Go to C:\android-sdk-windows and open sdkmanager.exe.
After it is open, a windows will pop out, click reject on all files except for:
Android SDK Tools and Android SDK Platform tools.
Make sure USB debugging is activated (On your phone go to settings> applications>development and check USB debugging) Then open up Cmd and type the following: cd C:\android-sdk-windows\platform-tools.
NOW you'll be able to input the commands needed to flash the Custom Recovery in this thread
Finally Custom Recovery for 2.2.1 stock phones !!!!!!
okay so i did all this and do i open the command promt or the command thing in sdk and plus i put usb debugging on and my computer couldent install the drivers :/ so yeah help
Here are the drivers for your phone.
Download them and install before connecting your phone.
http://www.lg.com/us/support/mc-support/drivers/LGMS690.zip
After the drivers are installed, plug in your phone, DO NOT turn on USB storage.
Hopefully you've already put the 2 recovery files on your sdcard.
On your PC click Start>Run>type cmd.exe and then enter
cd C:\android-sdk-windows\platform-tools which is the path to the program that will push or install the 2 files onto your phone from the sdcard.
Now continue forward using the commands outlined in the thread:
http://androidforums.com/optimus-m-...nally-custom-recovery-2-2-1-stock-phones.html
If you do not get the # symbol the first time, try it again and watch the screen on your phone for SuperUser, it may ask if you want to allow super user rights.
(See Attached)
Just click Allow and proceed.
Good luck! The door is open, be careful to read and follow the instructions outlined in any thread you are reading.
Make sure it absolutely pertains to, not only your phone, but the Android version on it.
Don't jump in if you have any doubts about your abilities, read some more to gain confidence and be prepared for those oops moments.
Once you get Custom Recovery installed, the first thing you MUST do is create your first nand backup. It will save your ass if you make a mistake or something strange happens after you've decided to install a ROM.
i got to the part where you haved to type in "su" everytime i do that cmd says "su is not a recognized as an internal or external command, operable program or batch file. ._.
now dont get me wrong ive done allot of flashing and work with clockworkmod recovery i know how to do the flashing part its just the custom recovery part and i have complete trust in myself to do this
After you enter cd C:\android-sdk-windows\platform-tools
it should return C:\android-sdk-windows\platform-tools>
type adb and see what the response is.
It should look like the attached image.
If it doesn't, then check to see that your install path is correct.
