Help CyanogenMod 9 alpha4 clockworkmod problems
Hello all,
I flashed the new Cyanogen ICS rom. I have CWM5 but when i boot into recovery I can select the options but the power button doesn't do anything. I cant flash, cant reboot nada. I have to battery pull and reboot to get out of it. I tried re-flashing the recovery but ended up in same place enev after a nandroid restore or flashing to stock rom.
thanks!!
You have to activate it, by pushing up, down, up, down, up, down, on the vol. Key, it will say "button enabled" then you should be able to execute a command.
Depending on which CWMR you have some of them use the home button to make selections, and some use the power button.
