Root cyanogenmod help
air_a20
Hi im going to get cyanogenmod on my motorola milestone i want to know if it will work on mine im with telus an mines at 2.1-update 1. i found this site but im not sure if its correct http://android.doshaska.net/node/17 also if someone can help me install it by telling me how to because im not that amazing with it that would be amazing thanks in advance
you should have android 2.2 by G.O.T, you can find it here ( G.O.T.'s Blog )
then from the website you found download this file ( androidiani-openrecovery - Project Hosting on Google Code ), extract & copy to root of your SD card,
then download ( https://github.com/downloads/nadlab....31-cm-6.1.0-RC1-Milestone-signed.zip/qr_code ) & also ( http://cyanogenmod-mirror.local.host.name/gapps/gapps-hdpi-20101025-signed.zip ) & copy it to this adress: "/sdcard/OpenRecovery/updates".
then reboot your phone into Recovery mod & press "apply sdcard:update.zip"
then press "apply update" & from the menu first apply "update-0.03-10....." & then "gapps-hdpi......"
& now reboot & enjoy
This's the same thing I did & it works very good, but I'm not responsible for any mistake you make...
if you had any question just ask me
