Help Cyanogenmod power control like widget?
jkc120
Android Expert
For any of you folks who have used Cyanogenmod 7, do you know of a power control widget in the market similar to it? I loved all the different toggles it had, but more importantly you can configure which toggles it shows (up to like 6 or 7 I think?). Anyway, if anyone knows of a good one that has the flexibility of the CM7 power widget and works with ICS (and has the ability to toggle between 2G/3G or 2G/3G/4G etc), I'd really appreciate any app advice!
Thanks!
Tried it, and fortunately was able to use the refund button, since it didn't play nice at all in ICS. I couldn't find a way to add the widget with the default ICS launcher. :(
I wasn't so lucky to get a refund, 5 minutes after buying it I tried the refund and got a message saying it can't process my refund at this time. I know its only a buck but I hate paying for something that doesn't do something it claims to do.
extended controls works just fine for me with the exception of the GPS and 4G toggle. if your widgets are not showing up immediately, try a reboot. this has solved the issue for several other users. this applies to all widgets, not just extended controls.
personally, i can't wait until we see a ROM with the power widget cooked into the drop down notification bar. there were several like this for the thunderbolt, and i am sure we will see this feature from the GNex devs soon!
I wish I could find a decent one that would work properly to turn off and on the GPS. So far they all seem to take you to the settings.
