sniper8752
before installing cyanogenmod and superbricking my phone, i just want to make sure that this doesn't apply to me:
"Some second-generation Samsung Exynos devices are potentially susceptible to a "superbrick" caused by performing a factory reset with the stock kernel, which effectively kills the internal memory in the device. It is highly recommended you do not perform this operation while using a stock kernel for safety reasons. The install guide assumes the device is already running stock Android 4.x.
" -- I777 Info - CyanogenMod
How do I know if I am safe?
