Same here... curiosity is killing me haha. My only issue is the only way I've pulled a logcat is with catlog which puts it on the sd card... the one I can't access lol. So I'll need to do a google search to get the command - no biggie.
Exactly
Now on to the reason I loaded it in the first place... To test the 1080p video recording gallery fc issue.
I'm sure this is a n00b question that a three-year Android user shouldn't have to ask, but is flashing a kernel the same process as flashing a ROM? Just clear cache and davlik? Do I need to clear data as well?
Dalvik and cache only, no data
Also, can we get a source link to current builds in the OP? I see a few github links thrown around in the thread but it should be clearer where the actual source is
Hah. The fun of customizing things.
To be clear, the gallery/video recording fc seems to be caused by an OOM issue, which it looked like you addressed that with some of the tweaks.
The video playback/streaming is something else completely, which seems to be as a result of the plethora (yes, I said plethora) of av commits recently done. Those were the reason I was on 5-22 nightly originally - that was to most recent I had before the commits.
Sorry for all the rapid fire updates. They should calm down a good bit here in the next few days.
V34 up.
I also turned the max current for the lcd backlight down from 22.5mA to 12mA. I'm not sure if this will be too dark... or really even save any battery life... But I've always felt that the screen was too bright at the brightest setting which should draw juice for no reason.
Let me know how it works out.
You're kernel doesn't like beta 4. I just tried it and it wouldn't boot. Albeit I did only do a dirty flash.
I was getting some weird light issues on v34, seemed to be related to the status bar brightness slider. Was just a bit quirky, would dim down and then get bright again occasionally, not all the time, and brightness would flicker sometimes. Was pretty random, on v35 now, I'll let you know if it keeps happening and if I can pinpoint why. Just thought I'd let you know.
Battery life seems better, although still not great, you'll be a superstar around here if you can improve that!
Speaking of Bluetooth issues, I have them as well. My Pioneer deck connects then disconnects after a little bit of time then sometimes reconnects and sometimes doesnt
V35
You wouldn't have a log cat would you?
Sounds like what I saw a patch for that now I can't find again.
Sent from my VS920 4G using Tapatalk 2
Need to generate one....have terminal on the phone what are the commands...
