slikrider20
Hello all, i have the ICS leak .232
When i first installed it, 4G worked fine on it. I wanted to turn 4G off, and apparently the "Phone Info" app is the only way to do it, which i don't understand.
Anyway, there are a bunch of different settings you can change it to. The only one i can get 3G to work on is CDMA auto (PRL). I want to turn 4G back on but i've tried all of the other choices but it won't turn back on. I've tried rebooting, killing apps, pulling battery, etc. Any help would be great.
