Hi every one
i need help plz i want to move Dalvik cache to Ex-sd and make the ex-sd the default location for dalvick , i'm using galaxy ace S5830 rooted, CWM , busybox , terminal and root explore installed , my android v 2.3.5 stock rom
help me plz i don't like custom roms
). But if you're command line savvy, using the terminal emulator is clean way to go about it without adding another program to your resource drain.
:Hi every one
