Root Dalvik (Froyo) with JIT for Donut
I see.
Thanks for your replies. I think google should have made a neater theme system, where you could change stuff like icons, backgrounds etc. on a higher level without messing with the core system files...
Thanks jakax. Due to this mod, I found that SetCPU was lagging my phone due to some settings.
Reaching 4.7MFLOPS in Linpack, can't say how faster other applications perform, since I ain't a machine :) It does seem to work though,
Some Benchmarks:
Linpack
2,412
4,903 with JIT --> 2nd argh^^
CPU Benchmark
2700 ms
2387 ms with JIT
Benchmark
CPU 200
CPU 431 with JIT --> 4,03 Mflops DP | 7,45 Mflops SP
Graphic 151
Graphic 170
Memory +-0
Filesystem +-0
Neocore:
33,4 FPS --> +-0
nice one!
Just updated Galaxo 1.6.3.3 on my Galaxy i7500L.
Worked like a dream. Just had to apply patch, delete Launcher.odex, then I applied the new ADW launcher from Downloads | Android Codex
no difference in graphics FPS, but CPU benchmark increased a bit
2896ms @ 710MHz
2542ms @ 710MHz w/ JIT
Thanks, works like a charm! Managed to get 4.908 on linpack after xx attempts, anyone gotten above 5 somehow? :p
Donut does have a working camera. Froyo, so far no. If you are having problems with the donut camera, install another app, like Camera Magic or Camera360. It worked for me.
There is another thread on that.
Cheers!
Jakax: just in case you like stats.
For the month of July:
-The second Version (non flashable) of your file got about 7k hits too.
hi,
i tried to install this dalvik onto galaxo 1.6.3.3 but i'm getting less than 1 on linpack.
To install i did the following operations:
1) boot into recovery and wipe
2) flash galaxo 1.6.3.3
3) restore g.apps
4) deleted launcher.odex and reboot
5) reboot in recovery
6) fix permission
7) flash jit_by_jakax.zip
8) reboot
Where i'm wrong?
thanks
It's due to the scalling rate
before trying a benchmark
overclock the min freq to 710 ( with overclock widget or other apps like that )
don't forget to downclock after the bench
@infect after installing JIT, applied DarkSense2.0_Advanced-Standard theme and after rebooting it is struck at infinite boot screen animation??? deleted launcher.odex also.. any more steps should be followed?????
I tried pushing the files to /system, but it keeps hanging at testgps.odex
Anyone else having this problem? Or should I just wait longer? I wait for about 5 minutes now.
