damage 2.09.1
parmend01
i just flashed damage 2.09.1 and the weather clock widget is gone and the htc music widget is gone too. There are other widgets gone also. I went back to fresh 2.1.2 and the weather clock widget was gone too. did i do somthing wrong? i wiped and reflashed and still same thing "missing widgets".
I just flashed to the DC 2.09 also, everything is there and works just fine. As stated before, try rebooting if that doesn't work, wipe and re-flash. Try wiping the Dalvik also.
I got stuck in a boot loop when I tried going from 2.08 to 2.09. How did you get yours to work? I used the DC Updater.
