Little update for everyone.
I downloaded via DcUpdater first and tried to wipe and install from Recovery mode but the file goes into the DCUpdater folder on the SD Card, not straight onto the card. Had to move it out of the folder directly onto the card. I wiped basically everything, did a fresh install, and got stuck in a boot loop. I pulled the battery, and pulled my SD Card, booted and it loaded everything up just fine. I lost my programs, but that may have been the result of upgrading my Recovery Image. I've seen that just updating it from DCUpdater has worked fine.
After the boot loop situation, it's installed and is running just fine. I've had a couple application problems that required me to Uninstall the program and then redownload it. All other aspects are functioning 100%.
There is a DC Config program that Damage installed, and in here you can remove the sprint bloatware, IE Nascar, Navigatation, etc. You can also remove other programs and can tweak the phone in here.
Other than that, all my contacts synced, FB synced, I'm getting all my texts/emails/calls.
If anyone has any questions they want answered in more depth, just ask and I can do a more thorough explanation.
