entelechy3
Member
Hey all, I've been using DoubleTwist to sync music between my Eris and my MacBook Pro without any problems for the last few weeks. The last two times I've synced, however (yesterday and today), that has changed. After syncing, I go through the usual disconnecting procedure (unmount from computer, unmount from phone, remove cord, etc)... except it tells me that my SD card is damaged, and won't read anything. So, I have to format the thing, and then re-load everything back on.
SD card has had NO other issues. I can load music (or pictures, or contacts, or anything else) onto the SD card either from Windows, or just using drag-and-drop in the Mac OS, without any 'damaged SD card' issues.
Anybody else have this problem? I've noticed it seemed to coincide with Doubletwist telling me, for the first time, that I needed to "update" purchased iTunes songs or they wouldn't play... could be a red herring, but odd that after my machine gave me that warning for the first time, my SD card needed to be wiped.
