Kaleb Randleaxe
So, I recently flashed to Hateraid 1.5. It came with GO Launcher, so I figured hell, might as well try it out. Well, as it turns out, I really, really like it. And I really, really like Hateraid 1.5 as a whole.
The problems comes in when I like my colors to match globally across my phone.
Hateraid has red icons in the notification bar for system items (Wi-fi, 3G, battery, etc). This is kind of... actually, REALLY gaudy in my opinion, and doesn't match with anything else on my phone. It really sticks out like a sore thumb.
On top of that, the messaging widget for GO SMS has a blue header, which makes it even worse (image attached).
So, my questions are:
1) Can you change the notification bar COMPLETELY without changing to a whole other ROM? For example, could I take the notification bar from a theme not built for Hateraid and use it with Hateraid?
a) If not, is there a way I can just change the individual icons manually?
2) Are there skins for the GO SMS messaging widget? I looked around but couldn't find any. I'd rather be able to change it to a medium gray instead of the blue.
a) If not, can I alter it own manually?
Thanks in advance for any help. It's much appreciated.
