Root DarkAndroid for Tranquility 3.5
GregTard
Dark Android for Tranquility 3.6
Dark Android is a very detailed dark theme with green highlights for Tranquility 3.6. For more details and screenshots, visit my site Dark Android Designs.
The following system apps are themed in this version:
  1. Google Search Box
  2. Browser
  3. Gingerbread Keyboard
  4. MotoTorch/Ringer Widgets
If you would like to see Dark Android ported to another ROM, I gladly accept requests and I will see if I or someone else can do so in a reasonable amount of time. I am currently in need of testers or developers to work with me to expand my testing abilities and content since I only have a few testers and am using my primary phone to develop and test on. If you would like to test or help in development, please email me at daDesigns@mpmitchell.com.
As always, I am not responsible for anything that happens to your phone and all mods, including this theme and all others, have the possibility of damaging your phone. I will do my best to support my theme and assist with any errors that may be caused by this theme. Please read all instructions and entire thread before installing. Important information can be within the thread in user posts. Please remember that I do this as a hobby after my full time job so please allow adequate time for me to respond to a question or issue. Also, if you like my work and would like to help me continue my work, please donate.
To install Dark Android, download the package and follow the below instructions:
You should always backup your system before installing any ROM or theme.
  • Copy DarkAndroid.zip to your sdcard
  • Reboot into Bootstrap Recovery
  • Install zip from sdcard
  • Choose zip
  • Browse and select zip
  • Install zip
  • When complete, use back button or power button to back up
  • Reboot phone
There is also a goodies pack that contains lots of icons, wallpapers, LP docks, and alternate fonts as well as various themed market apps. To use the extra content in the goodies pack and market apps, download them into a folder on your sdcard.
  • The goodies pack should be extracted onto you sdcard
  • The icons can be applied using Launcher Pro, Desktop Visualizer, Folder Organizer, or one of the many other choices for icon customization.
  • The docks can be used with Launcher Pro.
  • The fonts are in flashable zips so once extracted, they can be flashed.
  • Of course, the wallpapers are applied the normal way using the gallery selection or other tool.
  • To install the market apps from your sdcard, remove the .zip extension and install like any other app. (You must remove any existing version of the app prior to installing)
For more information about how to use Launcher Pro to modify your dock and icons, check out their user guide here.
Download Links
I have created a version for each animation with normal & transparent lockscreens. I have split these into the type of animation used for grouping. Each group has a version with clear sliders, transparent notification background, and non-transparent notification background.
Bounce Animations
Clear Lockscreen and Transparent Notification Shade
Normal Lockscreen and Transparent Notification Shade
Clear Lockscreen and Solid Notification Shade
Normal Lockscreen and Solid Notification Shade
Flip Animations
Fly In Animations
Fold Animations
Google Voice
Launcher Pro
Black/White Swype Keyboard
Goodies Pack
Visit Dark Android Designs or follow me on Twitter
