MetroNoob
If your having problems with the 3G losing connectivity, it is because MetroPCS Is increasing it's network. (Of What I've heard, but they have been doing this for two weeks now).
If you need to use your internet some type of way, I've set my phone to 1X only. (CDMA ONLY).
In order to do this you will need your MEID (located in Settings > About Phone > Status), MEID Converter - Free MEID and ESN conversion tool , and your brain.
1. Convert your MEID from the site above to get your MetroPCS SPC Code.
2. Once you have your code, open dialer on your phone and type ##33284# - Also known as the DEBUG MENU.
3. Click on HDR/1X Selection
4. Choose CDMA Only Mode and press OK.
Now your phone will only operate in 1X mainly around the MetroPCS Coverage Map. I know it's slow, but that's the only temporarily fix to the problem.
Have a nice day!
BY THE WAY. TEMPLE RUN IS OUT!!! BUT NOT (YET) COMPATIBLE WITH OUR PHONE. I HAVE AN APK BUT IT JUST FORCE CLOSES. https://play.google.com/store/apps/...51bGwsMSwxLDEsImNvbS5pbWFuZ2kudGVtcGxlcnVuIl0.
Have a nice day!
