Help Data connection failed
caseyatbt
Member
I bought a used working EVO. I activated it and I noticed that when I turn it on, The data connection does not start. When I go into Settings/Wireless & networks, the Monile Network says Connection failed. If I turn it off and back on, it connects fine. Is there a setting that I am missing that is causing this problem? I rooted it before activating so I don't know if I should take it back to stock. But I would prefer not to.
Sounds like you need to re-provision data.
from the launcher screen push menu > Settings > System Updates > Update Profile
If that doesn't work just visit the sprint store.
