Help Data Connection Issues
greggvr
I have an international plan on AT&T. I'm in Western Australia connected to the Telstra network. Have full signal, can make calls, send texts, but my data doesn't work. I can't access my e-mail or the internet. My mobile network setting under "quick settings" goes between saying ON and Turning On. I have allow data while roaming option checked as well as the enable always on on mobile data. Any help would be greatly appreciated! Thanks!!
When you are are roaming onto another providers towers they may have the ability to put a cap on the amount of data you can use in a month. I work for Sprint and even tho data roaming is included in our plans I have had many cases when a customer is not able to use data roaming after hitting this cap. In our case the cap is set at 300mb. I don't know if this is what is happening in your case but it's a thought.
I have one problem .. After flash phone recognizes the card but i cant connect to network..
What is the problem?
